Date/Time: Sun, 05 May 2024 00:14:17 +0000
Traditional P&F charting?
View Count: 429
[2021-05-31 23:18:55] |
58LesPaul - Posts: 429 |
I notice with the Point & Figure Bar period and Point & Figure XO Graph Draw Type that there can be a column with just one X or O but with Traditional Point & Figure charting it enables one step-back column building where there are no columns with just a single X or O. Is this possible with Sierra Chart? It really makes a difference when projecting range of next move. Thanks |
[2021-06-01 08:23:40] |
Sierra_Chart Engineering - Posts: 14224 |
Have a look at the Point and Figure Chart study: Point and Figure Chart It has an Input which should do what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
