Date/Time: Sat, 04 May 2024 23:26:47 +0000
Alert Code
View Count: 1072
[2014-03-13 11:36:37] |
infpz - Posts: 826 |
Please assist with the wording for this alert - Upon Bar Close, the alert sounds if 14 ADX is greater than 50, or when the same ADXis less than 20. Resets on next bar.
[2014-03-13 20:28:18] |
This is the Alert Condition formula: =OR(SG1>50,SG1<20) Here is the documentation to enter it on the ADX study: https://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html#EnterAlertOnStudy You will also need to enable these Alert options: Reset Alert Condition on New Bar Evaluate on Bar Close Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
