Date/Time: Mon, 09 Nov 2026 06:25:13 +0000
web based feature
View Count: 1052
| [2021-05-28 16:57:40] |
| User752442 - Posts: 36 |
Hello, I would like to use the web based trading feature. Think in must switch from CQG order routing to SC order routing .. is that right? Is the price equal 0,20 rt ?... and are there any other costs? |
| [2021-05-29 02:40:45] |
| Sierra_Chart Engineering - Posts: 25404 |
What exchanges did you want to trade?
| [2021-05-29 07:09:27] |
Eurex and CME
| [2021-05-31 13:46:58] |
| John - SC Support - Posts: 48459 |
Make sure you check with your broker about support for the Sierra Chart Order Routing Service for the EUREX exchange. Most of the brokers we know of are charging additional fees to trade on EUREX. You will find the information for the service on the following page, which also has the Setup Instructions: Sierra Chart / Trading Technologies Futures Order Routing Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
