Date/Time: Thu, 02 May 2024 08:23:57 +0000
Move to breakeven + 1 - Button
View Count: 1142
[2021-05-28 07:51:13] |
User361939 - Posts: 158 |
Hello, I create button for control bar "SL to 0" which is simply "Move to breakeven" command. I would like to add button "SL + 1" which means that STOP LOSS goes +1 tick(or any numbers of ticks) over Breakeven level. Is It possible to do it? Best Regards |
[2021-05-28 14:07:37] |
John - SC Support - Posts: 31293 |
There is not an option for a "Move to Break Even + 1" keyboard shortcut. But, you can set your "Move to Break Even" command to have a particular offset by entering a value in the Move to BE Offset field. Refer to the following: Basic Trading and the Trade Window: Set >> Move to BE Offset For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-10 08:50:06] |
Ty for information. I Found that it might not working properly with button. I have Chart1 and Chart2 Chart1 with offset 0 - when i click on button "move to break even" it goes to 0 Chart2 with offset +1 - when i click on button "move to break even" it doesn't go to +1 only 0 Is command "Move to break even" connected with "TradeWindow" where i can set offset? It's seems not or it's not working properly. Any thoughts about that? Best Regards |
[2021-06-11 15:49:16] |
Which "Move to Break Even" button are you using? We just verified that everything is working properly with the BE button on the Trade Window.
[2021-07-23 15:10:22] |
User330092 - Posts: 9 |
Going with this topic: Is it possible to create button the same as author suggested but "assign" button to the TRADE WINDOw TEMPLATE. We can create as much template as we want, with Offset +1, offset +2 etc then assinging to the button. This would solve the problem, but question is if , is it possible? |
