Date/Time: Thu, 02 May 2024 11:57:13 +0000
Volume By Price Study not Including all Date Range
View Count: 925
[2014-03-12 21:29:10] |
User54856 - Posts: 2 |
Hello. I am new to your application and have developed a chart using your Volume By Price Study guide to add the study. However, I want to go back to Oct-9-2013 and no matter what I do the study doesn't seem to consider all the data from that date to present. Is there something I'm missing? Thanks. |
[2014-03-12 21:46:20] |
What is the symbol of the chart? And when you scroll back to the very first bar, what is the date that bar?
[2014-03-12 22:24:38] |
Thanks for the quick response. I have attached a screenshot for your reference. The date of the very first bar is Oct 9, 2013. It seems as though the study stops including data below the 1733 price. Your thoughts? |
Volume Chart.jpg / V - Attached On 2014-03-12 22:23:49 UTC - Size: 224.75 KB - 367 views |
[2014-03-13 22:13:07] |
We see what you are describing. The solution is to set that chart as a Continuous Futures Contract chart: https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
