Date/Time: Thu, 29 Oct 2026 06:45:28 +0000
Older Sierra Version
View Count: 744
| [2021-05-25 14:16:21] |
| User808569 - Posts: 2 |
Please have a look at the picture in the attachment. I load an older Sierra version because I need it for my algos, you see? These older versions are also installed successfully. But as soon as I want to connect to the data feed I get the error message that I have to update again with the latest version. Is it not possible to install older Sierra versions? Can you please forward this to technical support? Thanks a lot Translated with www.DeepL.com/Translator (free version) |
| Attachment Deleted. |
| [2021-05-25 14:56:03] |
| John - SC Support - Posts: 48363 |
What you are seeing is correct. Due to changes to the data and other items, we have made it mandatory to be on a more recent version of the software. You will find more information on this here: Using Sierra Chart Current Versions is Required and Historical Data New Policy For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
