Date/Time: Tue, 14 Jul 2026 04:28:47 +0000
spreadsheet for trading - cell formating and validation list
View Count: 1387
[2014-03-12 17:40:17]
User60591 - Posts: 39
have a problem with Validation in Cell properties.
I windows i use ";" as list separator and when I use ";" in Input source validation works fine. Problem Is that when sierra restarts it changes ";" to "," and I must replace the comma each time I start Sierra.
Second thing is the cell formating issue with conditional formatting.
I wanna green colour fill ind the cell when the conditnon/ Value is TRUE. Only way I get this if I set:
Type: Cell Value
Operator: Not equal
Value: TRUE
After I close formating and I check it again Value is gone but it keeps on with propper cell formating.
pls check this out.
thank you
[2014-03-12 20:59:36]
It sounds like you are referring to features in the older spreadsheet functionality which we are no longer providing support for and will be eventually removed from the software.
Not quite sure where you are finding "validation", but conditional formatting is something that we do not support any longer.
Therefore, we recommend not putting reliance on these features.
[2014-03-12 22:00:45]
version 1097
right click on the cell--> cell properties-->validation
Idea is to select auto strategy to trade, i.e. long, short... with nested "if" in K and M
It works as I described in previous post.
Same thing with conditional formating, basically it works.
Does your answer means that this will not work after a certain point in future updates?
Date Time Of Last Edit: 2014-03-12 22:01:22
[2014-03-13 00:15:02]
OK, we know what you are referring to. We do not provide support for that feature and we expect it would become unavailable at the end of this year.
