Date/Time: Sat, 04 May 2024 18:12:08 +0000
i am looking to exchange tick data files
View Count: 1407
[2014-03-12 11:16:54] |
ariknoi - Posts: 31 |
i can give ES futures tick files from 2002-2011 and 2013 Dax future since 2009 (the source file is iqfeed and directly from the cme) i am looking for: ES continues contracts for the year 2012 ZB/ZN continues contracts as far as back as you have till 4/2013 Gold/Silver/Oil pls email me to arik.noi@gmail.com thanks! |
[2014-03-12 21:57:41] |
Have a look at the Sierra Chart Historical Data Service: https://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html It provides tick tick tick data going back three years for the CME markets. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-13 18:14:16] |
User61576 - Posts: 418 |
1. i installed another SC on my computer. which data provider should i choose for historical tick data? i didn't understand if i need to choose SC exchange data (not enabled on package) or should i select SC historical data 2. how do i d.l. as much data as possible? do you have any hours for that as iqfeed do? 3. is the source of that data is direct feed from the cme (to your servers) or is it 2nd hand like through iqfeed etc.? 4. did you ever compared the historical files between that feed and iqfeed? thanks |
[2014-03-13 20:46:27] |
1. Choose "SC Historical Data". 2. Refer to help topic 42.1 here: http://www.sierrachart.com/index.php?l=doc/helpdetails42.html We definitely have no restrictions like IQ Feed. 3. It is direct from the CME. 4. Yes. They are the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
