Date/Time: Sat, 17 Oct 2026 01:06:02 +0000
studies
View Count: 824
[2021-05-17 16:20:34]
User318521 - Posts: 52
is there any way to have studies displayed at the top of the chart instead of the bottom?
thanks
[2021-05-17 19:07:27]
John - SC Support - Posts: 48239
Yes, just enable the option for Use as Main Price Graph for the study to put it in region 1 and not have the main price bars there. Refer to the following:
Chart Studies: Settings and Inputs Tab >> Display As Main Price Graph
If you then want the Main Price Graph bars to display in a different region, then use the Chart >> Chart Settings >> Advanced Settings >> Chart Region option. Refer to the following:
Chart Settings: Chart Region (List) (Chart >> Chart Settings >> Regions >> Chart Region menu)
[2021-05-20 13:25:26]
No good DOM doesnt line up with the price action
[2021-05-20 13:29:39]
and is inactivated
[2021-05-20 16:01:17]
Yes, that is a downside of moving the Main Price Graph to a different region.
