Date/Time: Sat, 04 May 2024 00:10:19 +0000
Study files compiled on higher version do not show up on custom study list
View Count: 527
[2021-05-14 13:10:25] |
@sstfrederik - Posts: 403 |
Hi, From version 2238 and higher custom studies that have been compiled on higher versions where a SC update is required do not show up anymore in the custom study list. Previously one could see a line with "some filename.dll requires version 2255 or higher ..." Right now the file is just not listed. Can this be checked and changed to how this was previously? Thanks, Frederik |
[2021-05-15 13:58:07] |
bradh - Posts: 854 |
+1
[2021-05-16 00:12:18] |
We do not see how this problem is anything recent but must have been since the more advanced DLL loading method. Which has been out for about four months now. We will implement a solution.
[2021-06-20 08:42:56] |
do you still plan to check and solve this? When running an older version (ie 2256) a study compiled on new version (ie 2276) is just not visible in the custom study list. Thanks Fred |
[2021-06-20 21:52:33] |
This was resolved, but only in newer versions . We cannot do anything about older versions.
