Date/Time: Sat, 12 Jul 2025 00:57:19 +0000
Denali feed question
View Count: 535
[2021-05-13 19:38:18]
WheresMoney - Posts: 62
I am subscribed to Denali and normally use cqg/amp for clearing. I changed the trading service to IB and tried to pull up a stock, and the data came in (it came from IB; I could tell looking at message log). And if I pull up say EPM21, the data comes from Denali and execution is in IB.
So my question is: There are a bunch of exchanges that is not supported by Sierra. Like CFE requires additional Barchart subscription. Hong Kong / Japan isn't supported by any Sierra feed. If I enable those in cqg/amp, and "enable support for sierra data" and set my trading to cqg, can I pull up a Hong Kong symbol and the data would come from cqg while EPM21 would continue coming in from Denali? This is all within one instance, of course
[2021-05-13 20:39:30]
John - SC Support - Posts: 40857
Yes. That will work fine. You just have to make sure you are setup to get the real-time data from CQG for the exchanges that you want.
