Date/Time: Tue, 07 May 2024 16:40:36 +0000
volume profile question
View Count: 343
[2021-05-12 15:14:58] |
User148596 - Posts: 214 |
Hi, is there a way to make it so that the current RTH trading session is expanded so that it is easier to see. Currently the volume of the other days is are more so relatively the current session has a much thinner profile but it's so thin that I can't really see it very well
[2021-05-12 16:03:35] |
John - SC Support - Posts: 31433 |
It sounds like you have the option for Volume Profile Bars Length Relative to All Visible Profiles set to Yes. For what you are asking, you should disable this option. Refer to the following: Volume By Price Study: Volume Profile Bars Length Relative to All Visible Profiles For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
