Date/Time: Sun, 19 May 2024 01:42:30 +0000
Chart update interval less than 1 sec
View Count: 805
[2021-05-12 13:03:53] |
User97684 - Posts: 136 |
Hi, Is there a way to have an update interval less than 1 sec for a market depth chart? I am aiming to speed up the historical depth chart but all options i have explored lack some speed and fluidity . I have tried update interval based on vol, trades, range,... Many thanks |
ESM1-CME MESM1-CME [CBV][M] 0.25 Range #21 2021-05-12 13_.png / V - Attached On 2021-05-12 13:02:45 UTC - Size: 122.18 KB - 170 views |
[2021-05-12 15:32:32] |
The Chart Update Interval is set in Milliseconds, so any value less than 1000 is less than a 1 second update. You can not set it to be less than 10 milliseconds. We really do not recommend setting a chart with such an "intense" study like the Market Depth Historical Graph to be less than 400 milliseconds (preferably 500). Refer to the following: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
