Date/Time: Sun, 19 May 2024 01:11:17 +0000
Rithmic data
View Count: 428
[2021-05-11 17:22:42] |
User266447 - Posts: 250 |
Hello, I am using AMPfutures as a broker. Can I get Rithmic data from them and connect to Sierra Chart?When I go to SC click at file and then Sierra/TradeService Sttting I can see that there are two Rithimcs available: Rithimcs Direct - DTC and Rithmic Trading. If I buy rithmic will I be able to connect to SC? I trade CME and Comex products. Kind regards, Arek |
[2021-05-11 18:25:57] |
No Rithmic is not supported at this time.
