Date/Time: Tue, 07 May 2024 12:36:33 +0000
TPO chart won't show any data past March 15
View Count: 392
[2021-05-11 11:37:44] |
User425645 - Posts: 113 |
Hello, my tpo chart wont show any data past march 15, and won't allow me to change it in the chart settings either. Ill post pictures for clarification. Thanks.
Capture.PNG / V - Attached On 2021-05-11 11:37:31 UTC - Size: 162.73 KB - 142 views |
[2021-05-12 13:53:24] |
John - SC Support - Posts: 31419 |
You are using an expired contract (ESH21-CME). You need to rollover to the latest contract (EMS21-CME). Select Chart >> Perform Futures Symbol Rollover and select the current contract. Refer to the following: Chart Menu: Perform Futures Symbol Rollover (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
