Date/Time: Mon, 29 Apr 2024 18:45:16 +0000
Trading study needs position long or short
View Count: 448
[2021-05-11 10:25:13] |
User968625 - Posts: 256 |
Hello, First, I am trying to use the study "Trading System based on alert condition" but I need to know what to use to determine if my current trade/position is long or short and profitable or not. The study will need to be only activated to add to an existing profitable position when a certain condition is met so I have to find a way to make the study assess that (if I am long or short and profitable or not) second, quick quetion, can you have multiple of this study on the same chart (long and short) Thank you |
[2021-05-12 13:43:18] |
John - SC Support - Posts: 31187 |
You could use the Trading: Position Quantity study to know if you are long or short by checking if the value is positive or negative. Refer to the following: Trading Information Windows: Trade Data Studies You can have multiple versions of the study, but you will need to be careful about how they are setup, as they are going to be making changes to the same symbol. In other words, be very careful with your Alert Condition to ensure that it is not possible for both to activate if you do not want them to. There is no built-in method to do this, you would have to find a way to do it based on how you are setting up your alerts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-12 14:27:50] |
Thank you, John, I understand your warning and appreciate your input. I also can see how I can use the Position Q'ty to work
