Date/Time: Sun, 28 Apr 2024 19:25:44 +0000
[Programming Help] - Can't install C++ Compiler
View Count: 434
[2021-05-10 21:39:08] |
j4ytr4der_ - Posts: 918 |
I'm trying to start playing with ACSIL but can't get the compiler installed. Every time, it gives me: The Visual C++ compiler is not installed. Select 'Build >> Install Visual C++ Compiler' to download and install the compiler.
But I have already done that, and it wouldn't install, would fail every time asking me to point it to a "packages" directory which I don't have. I finally got it installed from the MSFT website but still, no go. What am I missing so I can get it to build? |
[2021-05-10 22:05:20] |
So build remotely worked fine, I guess it's just local building that is an issue. I'm ok with remote since it seems to work.
