Date/Time: Sun, 05 May 2024 11:37:27 +0000
[Programming Help] - Data populated before the day is over
View Count: 326
[2021-05-10 16:41:31] |
Alex C Demosthenes - Posts: 37 |
I got a new monitor and so I am using a new instance (for the first time) for that other monitor. Right now, it is May 10, 2021 and 10:38am where I live. However, you can see in the pic attached that the candlestick is already populated for the entire day today. This is the exact same Chartbook file that I am using in Instance 1. I would like to open certain Chartbooks (created in Instance 1) in Instance 2, which is the case for the pic I included here. However, with the data fully populated for the day (which is impossible since the day isn't over), I am not sure how to get this to work. |
SC Screenshot.PNG / V - Attached On 2021-05-10 16:40:48 UTC - Size: 55.34 KB - 142 views |
[2021-05-10 18:41:27] |
bradh - Posts: 854 |
Check your Time Zone in the Global Settings>>Time Zone Settings. If they are not the same, then that is most likely your problem.
[2021-05-10 18:53:07] |
Thank you!! That fixed it!
