Date/Time: Mon, 06 May 2024 07:44:21 +0000
connexion brooker a sierra chart
View Count: 732
[2021-05-10 16:38:09] |
Flamini Jean-Claude - Posts: 2 |
Bonjour, je n'arrive plus à retrouver sur site la fonction pour connecter mon broker a sierrachart ,comme il y a pendant la procédure d'inscription du compte. Est-ce que vous pourriez s'il vous plait m'indiquer le cheminement cette fonction. Merci d'avance. Meilleures salutations. |
[2021-05-10 19:55:39] |
John - SC Support - Posts: 31379 |
From Google Translate: I can no longer find on site the function to connect my broker to sierrachart, as there is during the account registration procedure.
Could you please tell me the path for this function. You will find the list of services at the following link. From there, select the particular service you want and it will take you to our documentation page for that service. You will then find the Setup Instructions for that service on that page. Supported Data and Trading Services: Supported Services OR you could just tell us what service you are using and we will point you to the instructions from there. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-19 17:00:34] |
Sierra Chart - Max - Posts: 5605 |
From User: Bonjour, j'ai un compte en suisse chez SAXO banque, est il possible de connecter mon compte sur sierra charts? Si oui, pourriez vous m'indiquer la procédure de connexion s'il vous plait ? j'aurais une autre question concernant la signature de contrat, il y a une case qui me demande l' "entreprise de compensation " s'agit t'il du compte bancaire a connecter ? Merci d'avance. Meilleures salutations. Sierra Chart Support |
[2021-05-19 17:26:58] |
From Google Translate: I have an account in switzerland with SAXO bank, is it possible to connect my account to sierra charts? If so, could you tell me how to log in please?
I have another question concerning the signing of the contract, there is a box which asks me the "clearing company" is this the bank account to be connected? Thank you in advance. You would need to check with Saxo Bank to see if they are using one of the listed services, particularly if they support CQG or TT for order routing. If they do not, then it would not be possible to use Sierra Chart with them. With regards to the Data Feed Agreement, the Clearing Company would be either Saxo Bank or the trading service they use, if they support CQG or TT. But first, you need to see if you can use Sierra Chart with your account at Saxo Bank. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
