Date/Time: Mon, 13 May 2024 21:30:50 +0000
conection
View Count: 1056
[2014-03-11 13:43:15] |
julian pineda - Posts: 60 |
I am having the same conection problem, have a lot of days with out working... need a solution. as soon as posibble
[2014-03-11 14:23:51] |
snillumat - Posts: 29 |
same problem here- I gave up on SC 4 years ago for same issues
[2014-03-11 17:40:48] |
Refer to: OEC Data Suddenly Not Connecting | Post: 27634 same problem here- I gave up on SC 4 years ago for same issues We do not know specifically what you are referring to. Connection problems always have an external cause. API components can also have been the source of problems and this is why we no longer use them and switched OEC to a non-API component. Refer to help topic 76 here:http://www.sierrachart.com/index.php?l=doc/helpdetails76.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-10 16:38:54] |
User5956732 - Posts: 12 |
Hi, I have a problem with it that I bought a data pakhet 5 at AMP him but I paid for you to Siera chart in the account I pakhet No.3. The problem with that is that I not numers footprints bars. Can you explain this ap oradit what to do so I could show footpritny? Thank you Radek
[2014-04-10 16:41:59] |
Contact us here using the account you purchased package 3 with: https://www.sierrachart.com/usercp.php?page=SupportTickets We will then change the package to 5 for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-10 18:37:56] |
thank you very muche. Radek |
