Date/Time: Tue, 30 Apr 2024 01:47:32 +0000
Order Configuration - Cancel Disaster Stop if position goes flat
View Count: 440
[2021-05-10 13:56:18] |
User337568 - Posts: 60 |
HI: I want to use the attached orders manually with "Use Attached Orders." Concept: Manually enter an order from DOM. - EX - go long Use Attached Orders enters a Disaster stop - 8 ticks away. EX - I exit the trade. Can the Stop be canceled automatically if the position is flat? I tried "Stop" without a limit and the stop doesn't auto-cancel if I exit the trade? It might be simpler to just make my target and Stop at 8 ticks and hope SC cancels the stop if the position goes to flat. |
[2021-05-10 18:37:14] |
John - SC Support - Posts: 31189 |
Have you tried this in Simulation mode to see what happens? You can try everything first this way to see how the system will react. Refer to the following: Trade Simulation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-11 06:56:22] |
There is a setting to do what you want. Refer to: Basic Trading and the Trade Window: Main/C >> Menu >> Orders >> Cancel Orders on Flat Position (chart specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
