Date/Time: Sun, 05 May 2024 03:21:16 +0000
sc.StartChartReplay() clears Trade Simulation Orders and Data
View Count: 745
[2021-05-09 16:34:26] |
Tony - Posts: 460 |
Hi, I just tried function sc.StartChartReplay(), when the function returns, all the Trade Simulation Orders are deleted. Wonder what is the reason? It didn't happen for functions: sc.ResumeChartReplay() and sc.PauseChartReplay() or when I just simply pressed the "Play" button in 'Replay Chart' Control Panel. Thanks very much! Date Time Of Last Edit: 2021-05-09 16:48:27
[2021-05-12 18:52:17] |
We will develop a solution for this. We will add a new structure member to control clearing of the trade data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-12 18:52:31
[2021-09-30 00:04:15] |
Tony - Posts: 460 |
Hi, Any luck fixing the issue? Thanks, |
[2021-09-30 10:29:33] |
Sierra_Chart Engineering - Posts: 14224 |
We started this but it was more involved to implement. We will make an effort to get this done, within a week. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-13 10:37:44] |
There is a new parameter in version 2320 to prevent clearing of the trading data data when starting a replay from ACSIL. Refer to: sc.StartChartReplayNew() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-13 10:38:00
