Date/Time: Thu, 03 Jul 2025 04:48:24 +0000
ACSIL - Associate a Tuple with each index in a subgraph
View Count: 654
[2021-05-08 21:27:26] |
backinblack - Posts: 40 |
Hi, I have a custom study where I am calculating some stuff and displaying it on the chart using usual: sc.Subgraph[0][Index] = <some float value>;
The above gets displayed on the chart as expected. Works all good so far. However, I am also looking to associate a Tuple/a pair of integers with every element of the subgraph array above without drawing them. EG, sc.Subgraph[0][Index] = <some float value>;
And now associate an int[x, y] with the sc.Subgraph[0][Index] This study is intended to be used by other studies and am looking to expose this Tuple via the Subgraph array above (In addition to the main float value stored against the Index that is being drawn) so that it can be retrieved/used by the studies which are going to be referencing this study. How do I do this please? Thanks J Date Time Of Last Edit: 2021-05-08 21:30:05
[2021-05-09 09:27:32] |
You can do this with Subgraph extra arrays: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].Arrays[][] Also refer to: ACSIL Interface Members - Functions: sc.GetStudyExtraArrayFromChartUsingID() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-09 11:39:00] |
That was very useful, thank you!
