Date/Time: Fri, 03 May 2024 10:12:52 +0000
Control Bar Issue
View Count: 413
[2021-05-08 20:53:26] |
RadioDC - Posts: 29 |
I just upgraded to the latest version from v2196. I'm using the Trading Evaluator- Delayed instance of SC. After the upgrade, the Control Bar is back to default settings. Is there a way to return to my custom Control Bar after upgrading?
[2021-05-08 22:01:03] |
There is a scenario that could be the cause of this. Exit from Sierra Chart and then delete the Sierra4.config file and then start Sierra Chart again.
[2021-05-09 11:22:20] |
Problem solved. Thanks for the timely response!
