Date/Time: Sun, 28 Apr 2024 15:19:27 +0000
Tool Configs Don't Migrate Across Instances
View Count: 433
[2021-05-08 10:21:33] |
User450463 - Posts: 113 |
Custom Tool Configurations don't seem to carry across instances. I set up my price retracement tool the way I want it in one instance, and when I check in another instance, it has the default, out-of-the-box configuration. I looked in the instance directories, and I don't see any obvious configuration file that I could copy. Is there a way to propagate the tool config to ALL INSTANCES? |
[2021-05-09 09:45:42] |
This can only be manually done instance by instance: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Copying Files Between Instances This configuration data is held in the Sierra4.config file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
