Date/Time: Fri, 03 May 2024 03:58:24 +0000
FXCM FIX multiple stops and targets
View Count: 964
[2014-03-11 12:51:57] |
bwalks123 - Posts: 122 |
If I am connected via FXCM FIX through SC and place an forex order in SC with multiple stops and targets do those orders sit with FXCM as OCO (one cancels other) orders on their servers? thx
[2014-03-11 23:30:14] |
In the case of FXCM there is server-side OCO. However as explained here, the Attached Orders are not sent until the parent order fills: https://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
