Date/Time: Thu, 02 May 2024 12:59:16 +0000
[Programming Help] - Bring back attached orders after cancel
View Count: 491
[2021-05-07 16:24:12] |
User104854 - Posts: 441 |
I use the attached orders when I trade. Sometimes I will go to cancel an order and right as I do I get filled and the attached orders get cancelled. I just didn't cancel soon enough. After this happens I'm in a position with no attached orders. Is there a way to bring back the attached orders after I am filled? If not, can there be a way to bring these back? Thank you.
[2021-05-07 18:59:17] |
Yes, refer to: Order Types: Send Attached Orders - Position/Price Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-07 18:59:27
[2021-05-08 12:45:59] |
Great! Thank you. Would there be a way that if ever I was in a position and there were no attached orders that they could be added automatically? A setting to do this perhaps? If this can't currently be done is this something a programmer would be able to do for me fairly easily? Appreciate it. |
[2021-05-27 00:26:47] |
Is it possible to have a setting or an option to have the attached orders automatically added in the event there's an existing position and the attached orders get cancelled?
[2021-09-01 15:47:53] |
Hi. I never heard back on my last question. Can you make it an option to add the attached orders automatically if they get cancelled and there is an existing position? Most of my trading is automated and if the attached orders were cancelled and I was away from the screen I'd be in pretty big trouble. I would really like to have the 'send attached orders by position' automatically kick in for protection. Is there a way to do this? Thank you. |
