Date/Time: Mon, 06 May 2024 14:51:08 +0000
s_UseTool BeginIndex does not plot in forward projection zone for DRAWING_TEXT
View Count: 404
[2021-05-07 01:43:38] |
Dema - Posts: 42 |
Hi Team, SC is not plotting the DRAWING_TEXT in forward projected zone bars using BeginIndex. It is fine for non-forward projected bars. Using Drawing Tools From an Advanced Custom Study: s_UseTool::BeginIndex For the subgraph I have in this study, I set the ExtendedArrayElementsToGraph property and it plots just fine. Could you please review/fix? Thankyou. |
[2021-05-07 02:52:52] |
We identified the problem and this will be resolved in the next release.
[2021-05-10 01:04:52] |
Dema - Posts: 42 |
Hi Team, Confirming that your fix works perfectly on SC v2256. I really appreciate your prompt work on this one as it had an important use. |
