Date/Time: Mon, 29 Apr 2024 15:31:11 +0000
DOM does not appear correctly
View Count: 362
[2021-05-06 21:07:59] |
User260950 - Posts: 10 |
Hello, Since some days the DOM for Binance does not appear correctly: e.g. for ADAUSDT BINANCE first BID is about 1.5 , first ASK is about 1.6 So the gap between ASK and BID is much too high. This also appears at other Binance Symbols Can you help? // Thanks, Arno |
[2021-05-06 22:30:45] |
John - SC Support - Posts: 31162 |
Please give us a screenshot of what you are seeing. It sounds like it is just a display issue with how you have the Tick Size and/or Price Display Format set. But if we can see it, we can have a much better idea.
[2021-05-07 04:15:04] |
Adjust the Tick Size and Price Display Format appropriately: Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
