Date/Time: Thu, 02 May 2024 02:33:58 +0000
Last Trade Price Box
View Count: 557
[2021-05-06 11:58:47] |
SierraTraders - Posts: 67 |
On the DOM price ladder "Last Trade Price Box" Is it possible to have the box extended over bid/ask columns Also is it possible to select "Current Price Box" to show the current price on price ladder |
[2021-05-06 14:41:27] |
John - SC Support - Posts: 31293 |
Is it possible to have the box extended over bid/ask columns No, this not supported. But, be aware of this setting that may help you with determining price for a trade: Global Trade Settings Windows: Chart DOM Highlight Box Includes Price (Global Settings >> Chart DOM Settings >> Other >> Other Settings) Also is it possible to select "Current Price Box"
to show the current price on price ladder How is this different from what is there now? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-06 15:15:47] |
sorry meant to say: to show the current position on price ladder "Current Position Box" |
[2021-05-06 15:39:26] |
"Current Position Box" This is not supported either. You can move the order lines to be anywhere on the chart, including all the way to the right, so they are next to the price ladder. Refer to the following setting: Chart Settings: Trade Drawings Left Align % (Chart >> Chart Settings >> Trading menu) Another item is that if you use the Buy Order and Sell Order columns, then you can see your limit orders in those columns. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
