Date/Time: Sat, 04 May 2024 09:51:01 +0000
Does anyone else run into responsiveness issues with their system during the day ?
View Count: 421
[2021-05-06 05:13:01] |
GravisHTG - Posts: 303 |
Everyday , After about 1 or 2 hour of trading , my system always slow down a lot ( i can use it but it got some delay compare to fresh restart and loading ) and Even if I close all my program , It wont get back to fresh. Only a reboot cure the problem. I try to figure out what cause this. My Cpu never goes over 25% usage, 1 core never to 100% , my ram usage never get pass 60%. So , does any of you have the same problem, or had the same problem ? thanks in advance. ----- Note to add , I have around 50 chart on 5 instance at all time Date Time Of Last Edit: 2021-05-06 06:08:13
[2021-05-06 05:35:08] |
Sierra_Chart Engineering - Posts: 14207 |
Certainly users do from time to time report performance issues for various reasons. This is the relevant information we have on this: https://www.sierrachart.com/index.php?l=helpdetails30.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-06 06:12:29] |
I check the file , One step I couldn't do is how to check if memory release on windows 10. The step does not match. For the rest , It is ok , I already understand the step to make it run good. Its always after some time , at first its always fast as lightning ( and I know when its lagging because of a Indicator that tax to much resources. ) So , im just trying to figure out , if i can figure out how to fix the issues. I know that when I restart my computer , everything is fine And When I did some debugging, I restart the file DWM.EXE and It fix the issues like when I restart ( but cause a lot of bug as it is a critical program ) Date Time Of Last Edit: 2021-05-06 06:13:56
