Date/Time: Thu, 09 May 2024 00:17:03 +0000
Study image frozen
View Count: 338
[2021-05-05 19:43:34] |
User98657 - Posts: 304 |
This morning I duplicated a chart in order to create a new entry/trigger chart. One of the studies on that chart was the Clock-Real Time study. I don't need that on this chart so I deleted it along with a few others. However, the text block containing the image of the clock study is still showing on the new chart and is frozen at 11:13:18. The study has definitely been removed, I've tried adding it back and removing it again, I tried duplicating the chart hoping it would be gone from the new one, and of course I've closed and restarted SC. Any suggestions on how to make it go away other than rebuilding the entire chart? |
[2021-05-05 20:09:59] |
John - SC Support - Posts: 31480 |
The actual display is done by creating a Sierra Chart Drawing. It should have been removed when you removed the study, but since it did not, it is still there as a drawing. Therefore, you have to delete it as you would for a drawing - Right click on it and select Erase Drawing.
