Date/Time: Sun, 05 May 2024 11:31:40 +0000
[User Discussion] - spreadsheet issue
View Count: 932
[2014-03-11 04:35:42] |
toews&kane - Posts: 209 |
I am starting a new spreadsheet for some reason I have buy entry evaluate to true but it won't buy. Any reason for that? I can't think of why. -disable auto trading= false -flatten and cancel working orders=false -auto trading enabled -my chart is showing correct buy signal arrows -it's a simple trigger |
Capture.PNG / V - Attached On 2014-03-11 04:35:33 UTC - Size: 80.31 KB - 314 views |
[2014-03-11 04:38:17] |
We recommend referring to this section here: https://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#IgnoredSignals Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
