Date/Time: Tue, 07 May 2024 07:05:28 +0000
Traiding disabled
View Count: 320
[2021-05-05 16:32:09] |
Tėja Tamonytė - Posts: 1 |
Hello, When I want to trade it shows that my account is 'Unset' so I cannot trade. My AMP account is AC*****.Thanks |
[2021-05-05 18:23:13] |
John - SC Support - Posts: 31419 |
You are not setup to connect to your AMP account. You should be setup with CQG for your order routing with AMP, in which case you would have a CQG Username and Password. If you do not have these, then you need to check with AMP on this. Once you have those, then follow these instructions to connect your Sierra Chart to CQG: CQG Trading Platform Service: Setup Instructions Once the above is complete, then open your Chartbooks and select Edit >> Translate Symbols to Current Service. This will change the symbols of your charts to the CQG symbols. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
