Date/Time: Mon, 29 Apr 2024 10:27:49 +0000
Signing in with Gain Credentials
View Count: 406
[2021-05-04 16:21:05] |
gretat - Posts: 11 |
I have just downloaded sierra charts and I would like to use my Gain account credentials after my 2 week trial is up. How would I do that?
[2021-05-04 18:18:03] |
You can connect to your Gain account at any point. Just select File >> Data/Trade Service Settings and in the Current Selected Service set it to Gain Capital/OEC. Select the A button next to the service selection to see the list of items to be entered change under that section. Then enter the appropriate information for your account as necessary. Close that window and you are done. Just be aware, we do not offer any technical support for issues with Gain Capital. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
