Date/Time: Sun, 05 May 2024 14:58:10 +0000
slow data speed
View Count: 968
[2014-03-10 15:15:32] |
User21339 - Posts: 61 |
i use iqfeed and fxcm data feeds (have tried both fxcm data and fxcm trading settings) Data comes in incredibly slow, it can take an hour or more for historical data for a forex pair to come in. I have a default of 90 days history set, which is reasonable i would of thought. I dont have this problem when using ensign or metatrader, where data streams in very quickly indeed. Today was incredibly frustrating so much so that closed sierra completely. Are there any settings i can tweak to allow data to be processed quicker? |
[2014-03-10 16:17:47] |
Try using port 80: http://www.sierrachart.com/index.php?l=doc/helpdetails41.html The data downloading should normally be very fast . What you describe is going to be from an Internet connection issue. Good chance using port 80 will resolve this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
