Date/Time: Tue, 07 May 2024 06:46:16 +0000
DTC protocol development for custom data feed and trading server
View Count: 670
[2021-05-03 14:21:47] |
ybhx0315 - Posts: 1 |
Hi team, If I'd like to develop my own data and trading server and connect SierraChart with it using DTC protocol, do I need your approval to proceed? Will there be additional costs? Thank you. B.R. Charles |
[2021-05-04 05:51:40] |
Sierra_Chart Engineering - Posts: 14252 |
No approval is needed. No additional cost. You just create this and use the DTC Service Client within Sierra Chart. This is all documented here: Data and Trading Communications (DTC) Protocol Test Client It is described as a test client, but it can be used for non-testing purposes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-04 05:52:05
[2021-05-08 04:00:54] |
SabikiSensei - Posts: 74 |
@SC engineering As it stands, what exactly is the issue with the Rithmic Direct DTC integration? Is it just a matter of Rithmic sending over the necessary address:portals for specific data routes? I'm failing to understand why there is such long delay with this. |
