Date/Time: Sat, 31 Oct 2026 04:18:24 +0000
Grafici a lungo termine con giorni mancanti
View Count: 900
| [2021-04-30 19:05:57] |
| Ale83 - Posts: 26 |
Buongiorno nei grafici di lungo termine ( con tutti i dati presenti nello storico), mancano interi periodi. Ho questo problema su Future Nasdaq e SP500, come posso fare per risolvere? In allegato foto del grafico di lungo termine Nasdaq con tutti i giorni mancanti Grazie |
Private File |
| [2021-04-30 19:11:42] |
| John - SC Support - Posts: 48377 |
From Google Translate: in the long-term charts (with all the data present in the history), entire periods are missing.
I have this problem on Future Nasdaq and SP500, how can I do to solve? Attached is a photo of the Nasdaq long-term chart with all the missing days Follow these instructions to redownload the data for your chart: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
