Date/Time: Mon, 06 May 2024 02:42:33 +0000
Can you alternate long and short on a spreadsheet?
View Count: 988
[2014-03-10 09:12:02] |
HeavyMike - Posts: 25 |
Is it possible to somehow using spreadsheet trading to alternate going long and short. For example, once it goes long and exits, then it waits for the next short. If another long comes along, it will ignore it as the last trade was a long?
[2014-03-10 13:30:56] |
MotoMoto - Posts: 47 |
You could try using the value in $j$7 in a formula. 'Prior position Qty.' |
[2014-03-17 06:25:06] |
This should be possible, but the exact details do need to be worked by you. If it is difficult to do with Spreadsheets you can use the ACSIL trading functions. Just for completeness, here is the reference for Automated Trade Management: https://www.sierrachart.com/index.php?l=doc/doc_AutoTradeManagment.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
