Date/Time: Tue, 07 May 2024 19:17:02 +0000
Can you submit a limit buy order with spreadsheet
View Count: 919
[2014-03-10 06:15:37] |
HeavyMike - Posts: 25 |
Right now, if the 'K' column is true, the system will submit a market order. Is there a way to submit a limit buy order based on the last price of when column 'K' was true (assuming signal on bar close)? |
[2014-03-10 06:58:52] |
Yes. This is documented here: https://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#BuyEntryLimit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
