Date/Time: Sun, 05 May 2024 01:59:27 +0000
v1105 No recent bid/ask on my DOM (CTS user)
View Count: 1067
[2014-03-10 05:28:21] |
Lowell - Posts: 1 |
Just updated to 1105. Did my full reset of symbols and everything is running good. Except there is no recent bid/ask data showing on my DOM. Same for cumulative last trade size. Anyone else experiencing this? Im using CTS. Date Time Of Last Edit: 2014-03-10 06:20:54
[2014-03-10 06:46:30] |
We will check on this.
[2014-03-10 10:02:23] |
This was the result of a bug in 1105 which affected CTS. The problem is now resolved. Update Sierra Chart by selecting Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-10 10:02:53
