Date/Time: Mon, 29 Apr 2024 05:15:07 +0000
duplicate candlesticks
View Count: 1020
[2014-03-09 21:16:26] |
G. Thierstein - Posts: 7 |
how can I avoid these duplicate candlesticks this is NQ14 with 21 ticks chart also occur at higher Ticks chart http://www.sierrachart.com/image.php?l=1394399693782.png |
[2014-03-09 21:50:50] |
When providing a chart, make sure it is a simple chart containing no studies, if the studies are not necessary. This is a very confusing chart which is hard for us to comprehend. To solve this problem update Sierra Chart to the current version and follow the instructions on this page: https://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-10 12:40:04] |
sorry tried again http://www.sierrachart.com/image.php?l=1394455150984.png |
[2014-03-10 16:59:51] |
What Data or Trading service are you using Sierra Chart with?
[2014-03-10 19:13:54] |
SC historical data for replay
[2014-03-10 22:39:33] |
As long as you follow the instructions here you should get tick by tick data for the NQ: https://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php Be sure to re-download the data in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
