Date/Time: Mon, 29 Apr 2024 09:48:43 +0000
Continuum via Mirus data supported with Sierra Charts?
View Count: 1500
[2014-03-09 19:33:16] |
User10436 - Posts: 2 |
I believe Continuum through Mirus futures is same as CQG connectivity for data. Is this supported in sierra charts? thanks for your time.
[2014-03-09 19:36:18] |
Yes. See: https://www.sierrachart.com/index.php?l=doc/CQGTrading.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-09 19:43:57] |
I dont see Mirus futures or Continuum listed as an option anywhere. Also, would this data include historical bid/ask data?
[2014-03-09 19:55:01] |
If Mirus offers CQG, then Sierra Chart will work with that service. The market data feed is provided by this service: https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions And it does include historical Bid Traded Volume and Ask Traded Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
