Date/Time: Sun, 05 May 2024 19:57:02 +0000
Volum by price
View Count: 1154
[2014-03-09 18:26:54] |
User59284 - Posts: 4 |
Hello, I have a problem with my sierra chart you have a capture off my screen below http://www.sierrachart.com/image.php?l=1394389449706.png |
[2014-03-09 19:52:56] |
Make sure Chart >> Chart Settings >> Volume at Price Multiplier is set to 1.
[2014-03-10 17:42:03] |
hello my set up was like that Volume at Price Multiplier is set to 1. Frid |
[2014-03-10 18:36:49] |
What is the Ticks per Volume Bar set to in the Volume by Price study? Go to Chart >> Chart Settings. Is the underlying chart a 1 minute Intraday data chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-10 18:37:00
[2014-03-10 19:43:30] |
see attachment |
stting.PNG / V - Attached On 2014-03-10 19:43:17 UTC - Size: 81.18 KB - 364 views |
[2014-03-11 21:54:25] |
Re-download the data in the chart by selecting Edit >> Delete All Data and Download. We understand what you are pointing out to us is the large gap between the horizontal volume bars in the Volume by Price study. That should not be the case as long as the proper data is available. This appears to be an underlying data problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
