Date/Time: Sat, 04 May 2024 15:52:36 +0000
SC symbol format for IB mutual funds
View Count: 1301
[2014-03-07 16:22:15] |
auggie - Posts: 45 |
Can someone tell me what the symbol format is for mutual funds on Interactive Brokers. The exchange is fundserv Thanks, Larry |
[2014-03-08 03:48:38] |
Do you know what the security type would be? Would it be the same as stocks? When you open the contract information through TWS for the symbol, you should see what it is.
[2014-03-08 14:07:27] |
I'm enclosing a screen capture from TWS because Type is listed twice... see attached .jpg Thank you Security Type FUND Family VANGUARD Type Stock |
Capture.JPG / V - Attached On 2014-03-08 14:06:25 UTC - Size: 38.55 KB - 402 views |
[2014-03-09 00:12:42] |
This is exactly what we need. This is the symbol to use: VTSMX-FUND-FUNDSERV-USD General Format: [mutual fund symbol]-FUND-FUNDSERV-[currency] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
