Date/Time: Tue, 07 May 2024 11:51:34 +0000
[Programming Help] - Alert at Top of the Hour SOLVED
View Count: 441
[2021-04-15 21:19:41] |
Metzenovich - Posts: 10 |
How can I have an alert that gets checked at the top of the hour? I've tried "MINUTE(BARENDDATETIME) == 0", "TIME(0,0,1) == 0)", and "MINUTE(sc.CurrentSystemDateTime) == 0" with no luck. Basically I want to check if conditions are true using AND(), but only in the first second of the first minute of the hour on a 60 minute chart. Thanks |
[2021-04-15 21:44:22] |
I kept looking after posting and found a solution that works for my needs: Alert that references time remaining in bar Essentially using the seconds left in the bar using the Countdown Timer study. |
