Date/Time: Tue, 07 May 2024 07:26:09 +0000
Properly deleting old futures data
View Count: 1083
[2014-03-07 13:32:13] |
bwalks123 - Posts: 122 |
Hi after reading over the documentation regarding deleting data I am still a little confused as to how to 100% remove it properly. I have a lot of futures symbols that I am not using any more and would like to remove all of downloaded data from my computer, is this done through SierraChart platform or do I delete certain files (SCID,.dly) from out of the data folder within SC folder on my desktop? Thank you
[2014-03-07 18:18:05] |
Here are the instructions: http://www.sierrachart.com/index.php?l=doc/doc_ChartDataFiles.html#DeletingCharts You can delete the files either from within Sierra Chart or outside of it. It does not matter. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-07 18:18:33
