Date/Time: Mon, 06 May 2024 00:06:59 +0000
Problem connecting with AMP / TTnet
View Count: 1179
[2014-03-07 07:47:12] |
User88548 - Posts: 1 |
Below is a copy of the message log: AMP/TTNet: Connecting. | 2014-03-07 08:35:34 Starting the Price Feed session. Connecting to 12.41.48.53 port 10501... | 2014-03-07 08:35:34 The network socket is connected. | 2014-03-07 08:35:34 TT FIX Data: Sending the Logon message. | 2014-03-07 08:35:35 TT FIX Data: Received a Logout message. Text = Unable to login to adapter AMPNON1ORPR: STEF26 is not authorized to use FIX Adapter.. Please contact your System Administrator. | 2014-03-07 08:35:35 TT FIX Data: Sending a Logout message. Text = Received Logout message. | 2014-03-07 08:35:35 TT FIX Data: Logged out and disconnected. | 2014-03-07 08:35:35 Disconnected from TT FIX Price Feed session. | 2014-03-07 08:35:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-07 08:35:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-07 08:35:35 AMP/TTNet: Disconnected. | 2014-03-07 08:35:35 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-03-07 08:35:35 Regards |
[2014-03-07 08:06:17] |
Contact AMP and let them know you are getting this message when connecting to TTNet: Text = Unable to login to adapter AMPNON1ORPR: STEF26 is not authorized to use FIX Adapter.. Please contact your System Administrator. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
