Date/Time: Fri, 13 Nov 2026 21:10:56 +0000
relative strength
View Count: 2343
[2014-03-06 20:16:49]
M5amhan - Posts: 468
I have decided to purchase SC. I was wondering if you could add a study called "relative strength". This is different than RSI but a simple calculation. This is pulled from investopedia (parenthesis are from me relating to the indicator for SC) :
Take the six-month (user defined bar length) rate of change in an investment's price (Chart #1) and divide it by the six-month (user defined bar length [same as first bar length]) rate of change in a relevant index (Chart #2). The investment's rate of change is divided by the benchmark's rate of change to get a relative strength value. If the value is greater than one, the investment is relatively strong; if the value is less than one, the investment is relatively weak.
It is a great study for people like me looking for the strongest performers to buy.
[2019-12-31 22:16:46]
JaguarPaw - Posts: 4
+1
[2020-01-02 06:06:12]
This can be accomplished by using these studies:
Add Additional Symbol
Study Subgraphs Divide/Ratio
More information:
Using the Basic Arithmetic Studies
[2020-01-02 21:18:59]
YES it works!!!
Thank you so much.
