Date/Time: Wed, 25 Nov 2026 22:11:56 +0000
SPX Chart
View Count: 1284
| [2021-04-10 14:13:50] |
| UserOne - Posts: 42 |
Please assist in creating a SPX chart with my own data via IB. I understand that there is only historical data from denali if I pay for via SC, but I have data from Interactive Brokers that works just fine as you can see on the screenshot. How can I use my IB historical data to populate the chart? Screenshot attached shows - SC SPX chart http://www.sierrachart.com/image.php?Image=1618063978403.png - SC SPX CFD chart (has different data) http://www.sierrachart.com/image.php?Image=1618063903622.png - IB SPX chart (attached) |
| [2021-04-12 14:42:58] |
In order to get the SPX data from IB, you would need to set the following option to No: Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) This will then have all the data coming in from IB. Another option would be to install a second Sierra Chart installation which is setup to just get the data from IB by having the option for Allow Support for Sierra Chart Data Feeds not enabled. Refer to the following: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-04-12 14:43:23
